I'd like to export the peak area's and retention times of a batch to whatever basic file format (.csv, .xls, .txt,...), but when i do so i can't find the export files back.
I did change the print settings for batch results to -> print -> destination: file -> .xls .csv and .txt with a File prefix 'versl'.
When i print (it is supposed to make exports when i press print?) those files are nowhere to be found.
Anyone have an idea what i could be doing wrong or what could be causing my problem?
thanks in advance for the advice!
Jasn
