Levothyroxine tabs
Posted: Tue Mar 25, 2014 9:42 am
Hi All
I'm busy testing Levothyroxine tabs as per USP. The USP dissolution test has the following statement:
"Sample solution: Pass a portion of the solution under test through a suitable filter. [Note—Before use, check the filters for absorptive loss of drug. ]"
Could anyone recommend a suitable filter? We have tried a few filters but our data is inconclusive as to whether it is the filter or analytical method that is causing the problem.
Thanks in advance
Mike
Thanks in advance
Mike
