8270 Calibration and Internal Standard Problems
Posted: Sat Mar 22, 2014 2:38 am
I'm having some trouble getting linear response for 8270. Almost the whole back end of the run has be be calibrated using a quadratic curve fit which results in the CCV and LCS not to pass even though the areas count/calculated concentrations for the targets are hitting in the 90% recovery range. Also, my internal standard revoveries are fluctuating a lot in my CCV and LCS standards. For example the 1st 12hr check will be at 100% ITSD recovery and 12hrs later the ITSD recovery will be 300%. To rule out prep I re-preped the CCV and reshot and still got an increased response for the ITSD compounds. However, the response for the targets remains the same as before so it lis not an increased response across the whole method. I'm running a HP6990/7973 in pulsed splitless injection mode at constant pressure with the pressure pulse at 30psi and backing down to 9.5psi with 1.2 mL/min through the Rxi5-SilMS column with a Restek sky single gooseneck liner. The standards that I'm running for my calibration cure are 2.5,5,10,20,30,50,70,100ppm standards with ITSD at 40ppm.
Thanks for any insight.
Steve
Steve
