A/D and open source software
Posted: Tue Mar 18, 2014 2:08 am
Greetings!
I've recently acquired a Waters 600e systems with a 484 UV/Vis detector. I'm trying to hook the detector up to a A/D converter and import the data into some open source software. I was planning on using peak simple but I'm afraid that I would need to purchase a $1600 A/D converter and the a/d converter I have will not work. I currenly have a Nelson Analytical 840 a/d converter. I haven't yet installed peak simple to see if I can get them to pair.
Has anyone had any experience using open source software and a/d converters with equipment like this? What have you found that works? Is there some older software out there that might help solve my problem?
Any suggestions or ideas would be appreciated.
DM
DM
