Agilent 7890A infinite incubation (Headspace)
Posted: Mon Mar 10, 2014 10:54 am
Hello, to start sorry for my bad English, I am French, but I will try to be most clearly possible.
Terms:
- 40°C, 5°C/min => 240°C (40mn)
- Column dB-Wax 30m*0.32mm*0.5µm
- H2 0.8mL/min, constant Pressure 29.09
- FID detector
- Time of incubation of the samples: 180mn
Software:
Management Frontier runner: Maestro
Aquisition management: Ezchrome
I have a problem with my GC, I work in Headspace and when I launch my sequence of 25 samples (26h ~ of run) my device incubates my sample N°6 ad infinitum (the 5 first did not have any problem in the injection and the aquisition).
Do you have an idea of why? I wanted to look at if there were a “Run Prep” but I read that it was automatic.
Thank you in advance
Terms:
- FID detector
Software:
