Varian saturn 2000 GC-MS diffusion pump heater current error
Posted: Sun Mar 09, 2014 3:59 am
Hi there.
I got here a Varian saturn 2000 GC-MS with some history, where on the MS part the diffusion pump control does seem to have some issues and I'm late to the party..
The fault message (I don't have it word for word unfortunately) runs along the lines of "the diffusion pump heater current being wrong".
The diffusion pump has the following type label:
The unit is being run in Australia, so we got 230Vac/50Hz.
The history of the unit is the following afaik:
Please check the following pictures for details (you can click on them to see a bigger version):
Now onto the questions I've got (thanks for reading so far):
Joan
Code: Select all
L9670-322
AX/65/165V/250W
FL.CHG. 30CC
S/N LDL80084The history of the unit is the following afaik:
- the MS seems to have burnt the original diff pump heating element, which I assume has been 165V/250W (which has been thrown away by the guy who did the replacement with the next spare, so can't say how it looked like)
- the replacement then being put in is still here and it reads:the diff pump didn't work with this one and it was found out that it was 220Vac rather than 165Vac, so a new one was ordered
Code: Select all
WATLOW ST.LOUIS 220V~ 250W TYPE CR 1328 09 L2A-853 - now there is this one attached to the diff pump now (after it had been found the 220Vac is not correct), but the error is still the same
Code: Select all
WATLOW ST.LOUIS L2A-106 REV D 165V~ 250W TYPE CR 1322 13
- anyone got any advise what I should be looking for?
- Is it normal to have a 165Vac heater run in a 230Vac country?
- The 6-pole connector marked in the pics has got a free terminal, that on the board runs directly to the controller for (I suppose) some sort of sensing element that goes out to the diff pump, but it's not populated here. Is that normal or does the MCU on that board miss some sensor info?
- The 2 blue marked adjustable resistors on the controller board seem to be for Current/Voltage sensing of the power that is running through the heater.. any info on what to adjust these two resistors to?
- If the hardware is fine, what about the controller on the board and it's software.. can it be replaced/sourced from somewhere?
- Does anyone have a schematic of that board or would know where to get it from?
Joan
