What the definition of minimum weight means as per USP
Posted: Thu Mar 06, 2014 3:17 am
Hello, first post here but I've browsed around before.
My question relates to the USP definition of what minimum weight means on a balance. I have been under the impression that it means the net weight (weight of the analyte) is the weight the minimum weight applies to. So, if you have a weigh boat that weighs 60 grams but your analyte (say, sodium chloride) weighs 20 grams and the minimum weight of the balance is 50 grams, it is not an acceptable measurement.
I'm asking because some people I've been talking to are under the impression that the minimum weight of the balance is applied to the total weight of boat and analyte (gross weight). In the USP is states explicitly that this isn't the case, but it seems there is no convincing them. Basically, they are saying that as long as your weighing vessel is above the minimum weight of the balance then you can weigh out basically any mass of analyte via weight by difference. So all they are looking at is the weight that is actually read off of the balance that is recorded, not the weight of the analyte.
Can anyone please shed some light on this? Thank you!
