Calculating amount of base needed for amine separation?
Posted: Sun Mar 02, 2014 5:02 am
I'm trying to separate a tertiary amine that has multiple basic nitrogens located elsewhere. First I'm curious, is there a way I can calculate how much base I need exactly to counter-act the interaction with the silica?
Secondly, if I want to translate a tertiary solvent system to a flash instrument what is the best method? Do I find find my base % and have it present in both solvents at the same level so it is always present as such? Or something else?
