Dionex Ultimate 3400 VWD invalid baseline
Posted: Fri Feb 21, 2014 8:59 am
Hello everyone
I have a problem with my Dionex UV detector: Since yesterday using an eluent with 0.3% formic acid it tells "Invalid baseline data [AZD]" when doing autozero. It was fine the day before. Using other eluents (without formic acid, or less concentrated formic acid) everything is OK. The manual says to check alignment of the flow cell. I don't think this is the cause of this problem, because I would expect decreased sensitivity or higher noise, but other methods still work perfectly.
Any idea (except from lowering formic acid concentration, I really need it
Thanks a lot
Jörg
Thanks a lot
Jörg
