Galaxie 1.9: issues with prostar 335
Posted: Mon Feb 17, 2014 12:18 pm
Hello everybody,
I got some issues with a prostar 335 detector, which is connected to a computer running galaxie 1.9.
The connection to the detector is established (I can turn the lamps on and off and I see the actual measured values), but when I start a sequence using this detector, no data is recorded, although the detector shows the actual values while the sequence is running. A second detector (LC-380 ELSD), connected to the same system records data well in the same sequence, while the prostar 335 doesn't record anything. The timeline says "-0,01 min" and stays there.
After a while the prostar 335 shows an error message saying that the runlog file is empty.
This doesn't seem to be an issue with the detector itself, for it is running perfectly, when it is connected to another computer (same windows version and also galaxie 1.9).
I have already reinstalled all drivers (for detector and network card) and I have dismounted a second network card from the computer, so there is just one left.
I would be really glad, if someone could help me!
thanks in advance!
thanks in advance!
