Varian Saturn 2000 - Ionization Failed not reaching 100uA
Posted: Sun Feb 16, 2014 12:25 am
Hi
Our varian saturn 2000 is failing ionization test reporting not able to set maximum emission current to 100uA, which is maxing out at ~80uA. I have checked filaments they were ok but still I changed the filament cleaned the trap but still failing. It is throwing following errors.
"The emission current can not be set to its maximum value of 100uA. Only 82.7uA is available. The likely cause includes. (1) Power control board is defective (Emission regulator) or (2) Filament is defective or 3) Manifold electronic assembly is defective (Filament select relay or connection)"
I have tried switching between filament 1 and 2, which switches fine as I can hear the relay clicking and I see ionization in manual control.
Please share your thought on this problem.
Thank you!
Thank you!
