Column conditioning of two columns in same oven
Posted: Sun Feb 09, 2014 4:29 am
I'm using Carboxen 1006 and Molesieve 5A PLOT columns in series for gas analysis. The temperature limit of the Carboxen 1006 is 250 C whereas the Molesieve 5A PLOT column has a temperature limit of 300 C. I really need to condition the Molesieve 5A column towards its upper temperature of 300 C but this would exceed the temperature limit of the Carboxen 1006 column.
I could take the Carboxen 1006 out of the oven in order to condition the Molesieve 5A column at a higher temperature than 250 C but I'd rather not mess with the columns. Would I get sufficient conditioning of the Molesieve 5A column if I simply conditioned for several hours at 250 C as a compromise? How far/long could I push past the temperature limit of the Carboxen 1006 before it degrades?
