General questions about Diluting Sample
Posted: Tue Feb 04, 2014 11:20 am
Dear all,
I am quite new on this field so I am seeking for help on the application of column DB-1.
I want to separate ethanol, acetic acid and ethyl acetate with DB-1 and FID. Do I have to dilute the mixture before injecting? If so, what kind of diluent would be suitable?
I found a Solvent Retention Data Table for DB-1 with column temperature etc.
http://www.chem.agilent.com/cag/cabu/pdf/b-0292.pdf
Thanks for any sort of help,
Nina
Nina
