Rutin&Diosmin HPLC UV reproducibil.probl. [Solved: Gradient]
Posted: Wed Feb 05, 2014 11:27 am
Hello to all! Sorry for my bad English
There is a Diosmin impurities&assay HPLC method in the European Pharmacopoeia. It is isocratic of 11% Acetic acid, Methanol and Acetonitrile. Diosmin is dissolved in DMSO. Nucleosil C18 column is used.
I used a consistent Nucleodur column and found the method rather fine. However any compound have only a relative time and it fluctuates a lot imho. Diosmin is eluted from 15 to 19 minute, chromatography must continue 6 more times because of Diosmin impurity F; and it is not so significant for incoming control but I have to develop an assay method for Rutin&Diosmin capsules.
I switched to H3PO4 solution with pH=3 (pH from 2 to 4 seems to change nothing, Et3N and KH2PO4 solutions too) and no Methanol and got almost the same chromatogram, of course I decreased organic content to about 15%. I added a gradient to 75% Acetonitrile after Diosmin eluted to flush all "long-playing" impurities and got rapid 20 minutes method
I got some problems with separating of Rutin and fast Diosmin impurities but it isn't a message.
The real problem is Rutin&Diosmin elution times non-reproducibility: my method has the same bug as EP one has. And now it is really important... I failed to try Zorbax Rq, CN and NH2 columns and I failed to switch to Methanol. Zorbax C18 provides the same result and also the bug.
There are ACQ Method, Test and Reference solutions prints:
https://dl.dropboxusercontent.com/u/162 ... m/meth.pdf
https://dl.dropboxusercontent.com/u/162 ... m/test.pdf
https://dl.dropboxusercontent.com/u/162 ... sm/ref.pdf
I ask for any help, any information, from personal experience or literature or any other source, any assumptions and ideas on the matter, any advice or suggestion on what to do or what to look at.
