Error message with verification tool on Chemstation B.03.01
Posted: Tue Jan 28, 2014 3:50 pm
How is it possible to run the verification tool on Chemstation B.03.01 without a column compartment?
When I try to do that, no test can be run and a simple error message is given with wrong value (-3.XXXXXe-38) for temperature, it seems that it need a column compartment to do the job
If someone know how to do, please give me the trick
Thank you very much
Thank you very much
