BFB continually failing 75/95 ratio.
Posted: Wed Jan 15, 2014 8:21 pm
Greetings!
I am currently having a problem passing a BFB tune for method TO-15(Air analysis method). My setup is a 5973 with a refuribished metal quad analyzer that has been in the instrument for a little over a year(The instrument as a whole is about 8 years old).
The problem is the mass 75/95 ratio, 75 is consistently high, typically around 70-80% or higher. I have taken serveral steps to troubleshoot the problem; new repeller, new multiplier, multiple source cleanings(the thing is sparkling now). I have utilized the Atune and BFB tune functions and manually adjusted settings, but no dice, mass 75 will not cooperate. I have even re-installed my chemstation software to rule out file corruption. I am currently waiting for new source parts to arrive and will be replacing those in the next few days.
Has anyone run into this type of problem or have any advice for lowering mass 75? I feel like it is some sort of hardware issue, but so far I have not been able to pin anything down.
This is my first post to the forums, so if there is any info I am missing or anything else that would be helpful, please let me know.
Thank you very much!
