HPLC 1100 Pump 1312A
Posted: Sat Dec 14, 2013 4:52 pm
Hallo Friends,
I have a 1312A Binary Pump which appears to be leaking solvent from the purge valve. I have tried to tighten the purge valve sufficiently. However this problem does not go away.
Also it seems that the capillary seat on the rim of the purge valve is also leaking. Is this a known problem. Should I replace the entire purge valve or would be it sufficient to replace the gold frit ?
Kind Regards
SG
Kind Regards
SG
