Chromeleon 6.8 calculate eluent volume
Posted: Fri Dec 13, 2013 9:38 am
by bunnahabhain
Hi everyone
Since some days Chromeleon on one of my machines does not calculate the amount of eluent required for the sequence any more.
As I am not the only person working on this machine I can't tell what was changed to make this happen. Any expert here who could help me bringing this feature back?
Thans a lot
Jörg
Re: Chromeleon 6.8 calculate eluent volume
Posted: Tue Dec 17, 2013 3:06 pm
by sbrand
Hello Jörg
If the "ready check" only shows the amount of predicted disk space, right click in this (the white) field. After clicking a context sensitive menu appear and the select "expert". I believe the choice is now "normal" or "advanced". After selecting "export" you will see the eluent consumption again.
Hope this helps to solve your issue.
Best regards,
Posted: Wed Dec 18, 2013 3:28 pm
by bunnahabhain
Thank you Stefan
This is it! Sometimes the solution is too close to see :)
Jörg
