Agilent 1100 pump/degasser is making a strange sound
Posted: Thu Dec 05, 2013 11:56 am
Hello.
I have an Agilent 1100 series.
This morning when I replaced the solvents I use (Hexane and Methanol) and switched the instrument on with thecpurge valve open, a strange sound started to come from the quaternary pump or degasser. This sound still appears when the purge valve is closed.
The normal sound from the pump is a "click.......click.......click", but sometimes it gives a 5 seconds "GRRRRRR..." sound just after the clicks.
My pressure is stable as well as my baseline and I no errors appear.
Does anyone ever had a similar problem? What can I do to solve it?
Thank you.
Thank you.
