Help with auto naming of report
Posted: Wed Nov 20, 2013 4:30 pm
by Mark from Santa Fe
Good day.
I am a relative newcomer to HPLC. I am using an Agilent 1100 system, autosampler, degasser, thermostatted column and DAD. Software is the standard Chemstation (3??) Revision B.
The current analysis work is identifying Carminic acid in samples from museum collections. Gradient elution using water and ACN each with .1% formic acid. Specimen preparation protocol is leaching/digestion with BF3 in methanol.
Having read through the macro programming guide and Chemstation manuals (standard Agilent) I have not found (perhaps not understood?) if it is possible to create a macro or addition to the report template so that when the sample run report is generated and saved to file, that it uses the sample name as the report title/name.
Is this in fact possible? If so, could someone kindly point me to a resource I can understand which would help or perhaps share the "code"?
More than a bit perplexed over this in Santa Fe.
Best
Re: Help with auto naming of report
Posted: Sat Nov 23, 2013 6:27 pm
by jenche
I don't know Chemstation macro language that well but I think you can access the data file name with the _datafile$ variable.
So you can probably modify the report macro to fit your need.
Posted: Tue Jan 21, 2014 6:53 pm
by nimbi63
I wrote this on many years ago, but it should still work.
name copy_txt
!! Retrieve destination directory if passed on command line !!
parameter copy_dir$ default "C:\LABWKS\HPDATA"
!! Declare variables local to this macro !!
local file_name$ ! Current .TXT file name in data file subdirectory
local new_file$ ! New file name for .TXT file
local retvar ! Generic function return variable
!! If destination directory and REPORT.TXT file found - copy!!
!! REPORT.TXT to destination directory as <Data File>.TXT - !!
!! else write error message to current LOGBOOK !!
If FILESTAT(MODE,copy_dir$) > 0 then !! Destination Directory Found
file_name$ = DADataPath$ + DADataFile$ + "\REPORT.TXT"
If FileStat(MODE,file_name$) > 0 Then !! REPORT.TXT File Found
new_file$ = copy_dir$ + "\" + DADataFile$[1:Len(DADataFile$)-1] + "TXT"
copy file_name$,new_file$,DONTASK
Print "Copied File '" + file_name$ + "' to '" + new_file$+"'"
WriteToLogbook "COPY_TXT: Copy Successful"
Else !! REPORT.TXT File NOT Found
WriteToLogbook "COPY_TXT: REPORT.TXT Not Found"
EndIf
Else !! Destination Directory Not Found
WriteToLogbook "COPY_TXT: Destination Path Not Found"
EndIf
!! Return control to system !!
return
endmacro
name COPY_TXT_HOOK
!! Check for current view = DA (Data Analysis). If so, add !!
!! 'User Macros' menu choices to Data Analysis view !!
If TabHdrText$(_Config,"Window","CurrentView") = "DA" Then
MenuAdd "User Macros","Copy TXT File","COPY_TXT",,\
"Copy TXT File To Other Destination"
Print "Custom Rpts menu added"
EndIf
EndMacro
!! INSTALLATION macro to create and/or append commands to load !!
!! macro COPY_TXT.MAC in USER.MAC file. !!
name Install_COPY_TXT
!! Append Macro commands to file USER.MAC to !!
!! add automatic loading of macro COPY_TXT !!
!! during Chemstation initialization !!
Open _EXEPATH$ + "USER.MAC" for append as #101
Print #101, ""
Print #101, "!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!"
Print #101, "!! Section Added By COPY_TXT.MAC !!"
Print #101, "Macro "+Chr$(34)+"COPY_TXT.MAC"+Chr$(34)
Print #101, "SETHOOK "+Chr$(34)+"PostDA"+Chr$(34)+","\
+Chr$(34)+"COPY_TXT"+Chr$(34)
Print #101, "SETHOOK "+Chr$(34)+"PreViewMenu"+Chr$(34)+","\
+Chr$(34)+"COPY_TXT_HOOK"+Chr$(34)
Print #101, "Remove Install_COPY_TXT"
Close #101
Print "COPY_TXT.MAC commands added to USER.MAC"
EndMacro
