Varying Peak Heights and Areas
Posted: Wed Aug 10, 2005 5:34 pm
We have been experiencing some variability in peak height and area for dissolution samples over the last few weeks. When samples are re-injected the next day, the values return to expected range (i.e. 100%). We are investigating whether the issue may be related to the dissolution apparatus or sampling technique, but we have not ruled out HPLC issues. either. Is there any possibility that the variability may be caused by electrical surges - we have had reduced power usage in this area over the last couple of weeks and were grasping at straws thinking it may be the issue. The variability has been seen with several methods, in a couple of labs on a variety of HPLCs.
Any thoughts?
Any thoughts?
