Chemstation B.01.03 / A.10.02
Posted: Mon Nov 11, 2013 12:25 pm
Good day,
I replaced a few days ago an old HP Kayak Win NT PC with an Win XP PC for our Agilent 5890 Series II plus GC/FID.
I installed a GPIB PCI card first and then Chemstation B.01.03. All works fine but there is an annoying problem.
I'm working with manual injection so I've activated "Sampling Diagram".
After a run I have to change the "Sample Name" in the "Sample Info" for the next injection.
It is shown on the left side. (Don't wonder, this is the Chemstation A.10.02, but it is in B.01.03 the same design.)
With the Chemstation B.01.03 the "Sample Name" does not change in the "Sampling Diagram". Sometimes it does, most of the time not.
In the Sample Info there is the actual Sample Name, when taking a Snapshot too. Only the display is not changing.
Also there is no error message and no entry in the logbook.
In the offline version of the Chemstation it works. I can change the Sample Name and every time it changes in the Sampling Diagram.
Does anyone have an idea how I can fix this problem?
Because the B.01.03 had this problem I installed the A.10.02.
Equally all works fine, even the issue with the Sample Name does not appear.
But there is also a small error: (At the bottom, in the Command Line)
It causes: nothing. All works fine. But it is annoying.
It just appears, when i'm closing the Sample Info when opened from the Sampling Diagramm.
When I open the Sample Info by the drop down menu under RunControl it does not appaer.
I would be happy if anyone knows a fix for one of the two problems.
Thanks alot for every assistance.
