How to wire a third detector to Agilent 1100
Posted: Fri Nov 08, 2013 3:10 am
Disposition:
VWD and MSD are already connected and work fine, now I need to add RID.
Both detectors and the ChemStation are individually hooked to a network switch. VWD is at the end of daisy chain with autosampler and pump. There is a "Remote" cable going from MSD to the pump.
All equipment is very old, purchased used, ChemStation runs on Win2k, if that matters.
Question:
How do I wire my RID? Should I add it to the daisy chain of the main stack? Should I connect it to the switch, just like MSD? Do I need another "Remote" cable? Do I need another JetDirect Card?
Searching Google and this forum did not help...
Question:
