Nonylphenol identification
Posted: Thu Nov 07, 2013 2:41 am
by Emi
Dear All,
I would be grateful if you could help me to understand the reason of getting same area at same retention time for different concentrations of nonylphenol.
To begin with, I am using HPLC-UV to identify nonylphenol in soil samples, the method is gradient of ACN and water 50:50 for 1 min then 0:100 for 10 min followed by 50:50 for 10 min. The wave length is 277.
I ran standard concentrations of 1, 10, 100, 1000 and 5000 ng/mL. I got the same peak area at the same retention time (14.58 min) .
Is this a saturation issue or what?
Looking forward to hear from you
Thanks in advance
Re: Nonylphenol identification
Posted: Thu Nov 07, 2013 6:20 am
by Gerhard Kratz
Please let us know a Little bit about your sample preparation.
Posted: Thu Nov 07, 2013 6:59 am
by Mattias
The most simple explanation is that the peak your are looking at is not nonylphenol.
Posted: Thu Nov 07, 2013 4:06 pm
by Consumer Products Guy
Yeah. And are you actually using (and looking to determine) nonylphenol or nonylphenol ethoxylate? Nonylphenol ethoxylate is what has been added to household and laundry products as a nonionic surfactant.
So my guess is that you are trying to determine nonylphenol ethoxylate environmental contamination here.
Posted: Fri Nov 08, 2013 4:44 am
by Emi
Dear All,
Thank you so much for your responses, I do agree with all of you that the peak is not for nonylphenol (4-NP). Therefore, today I have tried different (simple) method (ACN 80%: water 20%, wavelength, 230 nm) and I got a peak and the area is quite proportional to the concentration.
Currently, I am testing the standard and the detection limit for this method then I will work with soil samples.
Thanks again and your concern is well appreciated.
Posted: Fri Nov 08, 2013 2:59 pm
We used a little acetic acid in the aqueous, and we used 280nm detection (more specificity).
Posted: Sun Nov 10, 2013 3:15 am
by Emi
Thanks for sharing your method. I did use 280 nm recently along with 230 nm. However, I found the peak area is higher for 230 compared to 280.
I do not know yet the reason for increasing the response for 230 nm. Anyway, I am using both till I get the limit of detection. I will test both wavelengths in the real soil samples to decide.
Posted: Mon Nov 11, 2013 3:46 pm
The lower wavelengths will generally provide more absorbance, but also can detect other components in a sample, so the added specificity of the the higher 280nm wavelength typically helps us to detect lower levels because the baseline is better due to added specificity.
