H2 generators
Posted: Wed Nov 06, 2013 3:52 pm
by WK
Hi All,
Anyone use a PE hydrogen generator? Or any other H2 generator?
What are your opinions on them?
Thanks in advance for any thoughts.
Regards
WK
Re: H2 generators
Posted: Wed Nov 06, 2013 5:37 pm
by Consumer Products Guy
We've been using a Balston Parker H2 generator for several years, good and reliable. We use it for carrier gas for one unit and as fuel for several GC-FID detectors. We do not use any H2 cylinders here.
Re: H2 generators
Posted: Wed Nov 06, 2013 10:11 pm
by James_Ball
We purchased the Parker Balston unit also back in 2009 and use it to run the carrier gas to 14 columns and fuel for 4 FIDs, it is the 800ml/minute model. We have begun to have problems with it keeping up with demand, which we calculate to be about 500ml/min as we can now only run at about 24psi. After asking around 5 years is about the expected lifetime of the cells for many applications so ours is getting due for replacement, and it will cost about half the price of the total unit.
Even with those costs it has still paid for itself many times over considering the cost of about 4 cylinders per week of UHP Hydrogen we used before. We have the cylinders in a tank farm outside and have the building plumbed for gasses, so we put the Hydrogen generator at the other end of the gas run, keep it set slightly above the pressure of the cylinder end of the line so that if we have a power failure or generator failure we still have carrier gas as once the generator supply drops below the pressure set on the tank regulator the tank will begin to flow.
Most Hydrogen generators are of good quality just be sure to ask the sales person what the expected lifetime is for the cell and what the replacement cost will be when it is needed. If you size it correctly and have several instruments the payback will usually be two years or less, for us it was about 1 year since we use so much.
Re: H2 generators
Posted: Mon Nov 11, 2013 2:40 pm
by CE Instruments
We supply Hydrogen generators in the UK market. We have been very impressed with the low cost ones we supply and use in our lab. With the low cost system you do need to carry out basic maintenance, we have more expensive systems that are maintenance free. Contact me through our web site
www.ceinstruments.co.uk
Example price H2 510mL/min 99.999% 400kPA £2956 plus VAT. 1 year warranty
Re: H2 generators
Posted: Wed Dec 11, 2013 9:50 am
by oiltest
Producer and supplier of Hydrogen Generator in China.
High purity at 99.999%.
High quality and competitive price.
For more information, please visit our website
www.dgaequipment.com.
