Memory effect versus Source contamination
Posted: Tue Nov 05, 2013 2:23 pm
Dear all,
I am trying to learn more about calibration of ESI instruments and i am confused and stuck on a few facts.
From a book called Analytical Method Validation and Instrument Performance Veriļ¬cation, Edited by Chung Chow Chan, Herman Lam, Y. C. Lee, and Xue-Ming Zhang.
It writes that "The right calibrants for LC-ESI-MS should (1) not give memory effects; (2) not cause source contamination through the introduction of nonvolatile material; (3) be applicable in both positive- and negative-ion mode. "
However what is the difference between memory effects and source contamination? From what i have gathered source contamination is one of the reasons of memory effect and they should be the same am i right to say so?
