CoC Inlet Pressure
Posted: Tue Nov 05, 2013 12:29 pm
Hi All,
Currently having trouble maintaining pressure on our 7890A CoC inlet.
What happened was we wanted to swap the back inlet (originally the CoC) with the front (originally a SSL) for maintenance purposes. This was carried out by the contractor.
What happened was a drop in flow to the CoC inlet after a run.
My trouble shooting has found that it only happens post run.
I can change settings via the keypad to simulate the temperature and pressures but no pressure is lost.
I have run isothermals, post-runs that are meant to keep pressure while cooling, higher and lower pressures.
I am thinking it is a software/electronic conflict at some point, and FYI the conflicts of inlet swap were resolved in the methods we use on the software, but is there something we missed?
Will running a sequence solely from the GC keypad identify a software issue if a run was successful?
