Problems with baseline noise 5973 MSD
Posted: Sun Oct 27, 2013 11:20 pm
I am having problems with 'grass' type noise in samples run after a recent MSD clean. Noise is throught the 10 min run but seems worse as temp ramps up.
Note EM horn is getting to the end of it's life EM volts 2800
-First assumption was contamination so re-cleaned source.
checked all connections - blue entrance lens wire seems a bit loose at the pin.
-Tune is perfect with background peaks 178, ent lens & ion focus consistent with previous tunes. EM voltage 2600. so passes all checks.
-tried switching filaments -no difference to sample background
-trimmed inlet end of column.
-venting at the moment to reseat MS end of column.
Could it be column related as MS tunes seem ok? or is it a loose connection at the entrance lens?Tried the lens ramping but can't find a diagram anywhere in the help menu as to what they should look like.
Any ideas?
Any ideas?
