convertion of a data file generated by HP1100 chemstation
Posted: Sat Oct 26, 2013 7:28 pm
by fekihsonia
I'm using the Agilent 1946B simple quad mass spectrometer, I am running Chemstation B.03.01
I need to convert .ms file into .XML for further data processing
Do you have any free tool or procedure to do it
Thanks for any support
Re: convertion of a data file generated by HP1100 chemstatio
Posted: Mon May 05, 2014 3:19 pm
by cbartman
Did you find a solution? I am also trying to view/convert a .ms file. I have tried opening OpenChrom but I get a conversion error.
Posted: Wed May 07, 2014 8:35 am
by lmh
can you get away with netCDF which is the same as .aia, instead? Chemstation can export in that format.
Posted: Wed Aug 06, 2014 11:29 am
by eselmeister
Hi folks,
please send me demo *.ms files. I would then try to convert them by using OpenChrom. If an error occurs, I would try to fix the converter ... I'm the author of OpenChrom
https://openchrom.net/#contact
