How to remove FID from 6890 configuration
Posted: Thu Oct 24, 2013 8:55 pm
by zegockie
Should be easy but cannot find in manuals how to remove FID from Agilent 6890 configuration using keyboard. I use just GC/MS and FID is just the pain in the *ss during method development. Please advise.
Re: How to remove FID from 6890 configuration
Posted: Fri Nov 08, 2013 4:23 pm
by Bigbear
If you are using Agilent software the way to do it is to close instrument control and data analysis.
On the desktop there will be a shortcut to configuration. You should be able to re configure your instrument there.
