Negative peaks in blank sample - IC-Anion analysis
Posted: Tue Oct 22, 2013 9:16 am
Hi all,
I'm having problem of getting several small negative peaks (at 5.3mins, 6.4mins and 7.3mins-this negative peak is larger than the other), followed by a large peak (7.6mins) in my blank, which is just ultrapure water.
But when I injected my eluent, the baseline is stable and constant.
What does it signify? Any idea? I have got no clue of it.
The system I'm using is suppressed Metrohm Compact IC pro with conductivity detector. It's for my anion analysis, like fluoride, chloride, bromide, nitrite, phosphate etc.
Thanks.
Thanks.
