Pre-column and tailing
Posted: Thu Oct 17, 2013 12:36 pm
Hi!
I’m working in the organic gunshot residue (GSR) field and, currently, I’m developing a GC multi-residue method to analyse molecules such as nitriles (e.g., benzonitrile, tolunitrile, dicyanobenzene) and small (hetero-)PAHs up to 4 aromatic rings in GSR extracts. In order to avoid column degradation, I've installed a few days ago a pre-column on my Agilent GC/MS system. Unfortunately, after launching standards mix, I’ve noticed significant tailing on the peaks of some selected compounds. These are, especially, quinoline, all the isomers of dicyanobenzene, indole and the two isomers of naphthalenecarbonitrile (elution of PAHs was apparently normal). The analytical column is a 30m HP5-MS, while the pre-column I’ve just installed is a 4m de-activated uncoated column. I’ve have a PTV injector and a ramped injection method. Do you have any idea about what might be the cause? Is the pre-column too long, or maybe have I badly linked some connections? Or do the compounds interact with the uncoated column?
