idea for an injector program, not sure if feasible
Posted: Wed Oct 09, 2013 11:53 pm
Hey,
I am currently running an HPLC assay that requires a somewhat extensive sample preparation. This involves diluting up to 96 protein solutions at different concentrations to a concentration of 1 mg/mL with reducing buffer, letting the mixtures sit for 20 mins and react, then loading them onto an Agilent 1100/1200 for assay. I was thinking that I could maybe automate the whole sample prep. routine using an injector program in ChemStation.
I'm hoping I would be able to make a program that would draw from a vial of the reducing buffer and dispense and mix it into each sample vial to achieve 1 mg/mL, allow the solution to react for 20 mins, then inject the sample into the column.
Issues I see occurring with this are that I'm not sure I can tell ChemStation to deliver different buffer volumes to each vial through the injector program, and I don't know if I could get the cycles to overlap to minimize hold times for the samples.
Does anyone with experience in this know if this is feasible?
Thanks.
Thanks.
