Separating two peaks
Posted: Fri Oct 04, 2013 12:33 pm
hello,
I'm doing a limit test of dichloroacetic acid and monochloroacetic acid for lauryl dimethylamineacetic acid betaine
The problem is that the peak of dichloroacetic acid and a one of the peaks from the test substance have the same retention time.
which parameters should i change in order to separate those two peaks?
I hope the question is clear...
Thank you.
Thank you.
