HPLC analysis quantification with internal standards
Posted: Thu Sep 26, 2013 12:35 am
I was wondering if someone could help me here, I've got myself really confused using multiple internal standard calibrations.......
I recently developed a method to extract acids from my samples as follows - I take 10mL of my sample, extract into 20mL of hexane and then dry down. The extracted acids are then reconstituted in 5mL of MeOH ready for HPLC analysis. To this 5mL I also add an internal standard (200uL of a 200mg/L stock solution)
As for my standards, I made up a serial dilution ranging from 10-100mg/L from which I also take 5mL each and add the same amount of internal standard as above (200uL of a 200mg/L stock solution).
I have now ran all my samples but the numbers I've worked out don't make sense (I don't think), the numbers I am getting are higher than what I expect so I was wondering if someone could enlighten me on the following -
1) Does the ratio of IS to sample and standard matter for quantification? because in my case I'm adding 0.2mL/10mL sample while it's 0.2mL/2mL in my standards
2) Ignoring the IS, if say I get a value of 45mg/L by using unnormalized area, is this the amount of acids in the 5mL sample from which an HPLC injection was made or the amount of acids in the original 10mL sample from which the acids were extracted?
3) Finally, if I wanted to determine the total concentration of acids in the original volume of say 100mL from which 10mL was taken for extraction and as in the second question the calculated acid concentration was 45mg/L, do I just work out the equivalence of 45mg/L in 100mL or I also have to take into consideration the extraction and reconstitution step as a dilution factor type calculation?
