Compound identification in urine
Posted: Sat Sep 21, 2013 11:37 am
Hello to everyone,
As we know that acylglycines are important marker of inborn errors of metabolism.We can identify and quantify them in urine using GCMS. When i run hammers of glycines to identify them sometime i absorbed that the three identifying ions of a particular acylglycines were present in a specific peak at a specific retention time but when i select and search the NIST library match , it gives some other compound not the acylglycines. For example the identifying ions for propionylglycine are 159,188,131.When i extract ion using these three ions i found all these ions present at RT 15.4 min but when i select this peak and search for the match it gives the match with hexane-1,3-dicarboxylic acid, this compound consist above identifying ions in very small abundance and also contain other ions like 303,187.147.73 etc whose abundance is much more higher.
My question is how do we know this peak is of which compound because ions of both compounds are present in this peak , if both the compounds are co eluting then how to find their ratio in the particular peak please help.
Chandra
Chandra
