Integration events in CE Beckman equipment (Carat 32)
Posted: Wed Sep 18, 2013 4:01 pm
by MatCG
Hello everybody,
I have a question about how to integrate peaks when one faces up with complex electrophoretic profiles where many peaks appear together, side by side. Is it possible to achieve correct parameters (e.g. asymmetry, S/N, Resolution, Plates/meter...) by selecting concrete values of width and threshold, that is to say, in an "automatic" way? If it is possible, how can I select the correct values? If I must use the option "manual peak" then can I compare different electropherogram parameters?
Thank you very much and I'd appreciate some help!
