Hardware and method for Sulfur analysis
Posted: Tue Sep 10, 2013 1:26 pm
Hello all,
I'm trying to get an old GC started for Sulfur analysis. I don't know what hardware is recommended and what methods arevused for sulfur analysis.
The GC I'm talking about is a Chrompack CP9001. It has a split/splittles injector and a cappillary column installed (Wall coated, fused silica with a length of 10 meter and 0,53 mm bore), the detector is an FID.
My questions in a row:
- I know that for sulfur analysis a PFPD detector is reccomended, but a FID will do fine right?
- A long column is reccomended, so is it better if I install the same column with 25 meters of length and 0,32 mm bore?
- Can anyone give me an example of a method for the detection of sulfur compounds?
If you have any other tips for me regarding the sulfur analysis; please tell me
Thanks in advance...
