Help with AMDIS analysis
Posted: Wed Sep 04, 2013 7:48 am
Hello everybody,
I'm trying to use AMDIS to get area data for several hundred GC-MS runs.
As promising as it looks, I face a problem of non-identification. Peaks are identified as components, fall within the RT window and clearly have the same MS spectra of known compounds in the target library, but are not identified as targets.
In fact, with one sample I couldn't even get a "circular identification": I added the component to the library and reran the analysis, but the peak was still considered an unidentified component rather than a target compound.
Anybody has experience with this issue?
