Varian 3800 remain at "equlibrating"
Posted: Sun Sep 01, 2013 4:57 am
by alcorn
I have a Varian GC 3800 that worked 2 year ago but has not been turned on since.
When I load a method and after all variables set at desired values (flow, temperature and .... ), GC is stuck on "equilibrating" and dose not go to "ready" situation . I also select a name for my injection and press the "injection" in software, but GC is not ready for injection.
Another problem is FID is shut-down after several second. Each time I turn it on manually, It turns off again. All gases (H2, Air and make-up gas flows are correct). FID temperature is 200 0C and electronic is on.
Any help would be appreciated.
Re: Varian 3800 remain at "equlibrating"
Posted: Mon Sep 02, 2013 6:28 pm
by chromatographer1
Does the GC actually reach the set temperature of the method.
What method parameter is not met so the GC does not enter 'ready' mode?
Posted: Tue Sep 03, 2013 6:41 pm
by alcorn
All parameters are reach the set values and green lights are light.
