Missing Hexane Peak
Posted: Fri Aug 30, 2013 3:18 pm
Hello All,
I am new to GC (as in, JUST starting out) and already, issues... I'm tasked with analyzing reactor gas, but that is not where my problem lies. I'm struggling with the standard!
I'm hoping this will be a duh moment for me, so any input would be greatly appreciated!!!
I am running GC/FID on a gas standard that contains C1-C6. No matter what oven conditions and flow rates I run, I am missing a peak, which I believe to be hexane. I am certain I am getting methane, as the retention time is reproducible from another standard. and there are 4 other peaks, but no 6th peak. All components are at 100ppm in He. I am not getting full separation between methane and ethane, but there are 2 distinct retention times. I have varied enough the wrong way to completely coelude methane and ethane, but I can't seem to pull whichever component is hiding out!
Here are the ranges of variables I tested:
Carrier Gas: He (varied between 1 and 2 mL/min)
Inlet: 300 C
Detector: 300C
Oven Temp: 35C, 40C, 50C, 75C, 100C, 40C for 4 minutes followed by a 15c/min ramp to 250C
Split: 50mL/min, 10:1, 100:1
Please feel free to offer the most obvious solutions. Like I said I am very new to this, and think I should not be struggling so hard with a standard. Also, If you need other info, just let me know and I'll provide it.
Thanks for helping out a newbie!
Inlet: 300 C
Detector: 300C
