Agilent 6890 - Sig 2 buffer full
Posted: Wed Aug 28, 2013 10:50 pm
I am getting a frequent message on the LCD panel of our 6890 GC-FID system: Sig 2 buffer full. This is holding us up from running. Does anyone have any suggestions as to how to get around this problem?
We are running A.10.02 GC Chemstation. The system has only 1 detector installed at position 1 (signal 1). So for the signal 2 buffer message, what could be causing this? We are really needing to resolve this issue ASAP to be able to run larger sequences. It periodically pops up half way during an overnight sequence run and prevents the system from finishing.
Thanks for any suggestions!!
