Hexane As A modifier in Polar organic solvent chromatography
Posted: Fri Aug 23, 2013 12:28 pm
by sandy1989
Im an Amateur chromatographer
and i was trying to separate enantiomers of a drug on a lux chiral column by using polar organic solvent chromatography and i tried many permutations and combinations of the organic solvents, and at some point i was able to achieve a nice peak resolution with a symmetric peak shape only after using hexane as a modifier.
Now my question is whether can we use hexane as a modifier in
POSC? and let me tell u that there are no miscibility issues in there and i used only 10% of Hexane and the mobile phase contains MeCN and MeOH
Re: Hexane As A modifier in Polar organic solvent chromatogr
Posted: Thu Aug 29, 2013 10:30 am
by danko
Use hexane and be happy.
Posted: Thu Aug 29, 2013 10:38 am
by sandy1989
First of all.. thanks fr the reply
Danko
and am using Hexane and its good, but i need a help..... is there any method which uses Hexane and MeCN at a time in a mobile phase for HPLC
Posted: Thu Aug 29, 2013 10:52 am
by danko
I'm sure there is/are.
Posted: Thu Aug 29, 2013 11:49 am
by sandy1989
I tried a lot for the literature but couldn't find a single paper which uses both Hexane and MeCN as a mobile phase.
But if u have one can u pls provide me the link Danko... thanks in advance
Posted: Thu Aug 29, 2013 12:05 pm
by Csaba
Use iso-hexane and not n-hexane due to SHE issue.
And iso-hexane is much cheaper than n-heptane.
It works very well.
Posted: Thu Aug 29, 2013 2:37 pm
by danko
Hi sandy1989,
I can't provide a link to such a method and unfortunately I don't have the time to do a search.
But I can not - in my wildest fantasies - imagine that there aren't any instances.
best Regards
Posted: Thu Aug 29, 2013 3:26 pm
by sandy1989
Well Thanks for ur valuable time and suggestion danko....
Posted: Thu Aug 29, 2013 8:14 pm
by HPLCaddict
Just for a start:
http://bit.ly/15BBg4x
I don't have access to the fulltext, but "The effects of trifluoroacetic acid (TFA) and n-hexane concentration in an acetonitrile (MeCN) mobile phase were investigated" sounds like something you might be looking for.
Posted: Thu Aug 29, 2013 10:16 pm
by sandy1989
Thanks HPLCaddict and I have this article already but even I forgot that ,... it was helpful not totally but as u said its a Start...
Posted: Fri Sep 13, 2013 11:39 pm
by adam
Csaba:
Can you please explain what you meant by this: "Use iso-hexane and not n-hexane due to SHE issue."
Thanks!!
Posted: Sat Sep 14, 2013 4:47 am
by sandy1989
SHE is Safety Health Environment.....
Posted: Sun Sep 15, 2013 3:10 pm
by Csaba
SHE = Safety Health Environment - common aberration in the industry. n-Hexane is cancerogenic and you have to have a good reason to use it otherwise it is NO.
Posted: Tue Sep 17, 2013 5:28 pm
by uzman
Hi Csaba ,
I couldn't locate any Material Safety Data that mentions n-hexane is carcinogen.
OSHA , NTP and IARC classifies at not carcinogen.
NFPA Rating for Health=2
Posted: Wed Sep 18, 2013 4:32 am
by sandy1989
Hi follow the link below
http://www.atsdr.cdc.gov/toxfaqs/tf.asp?id=392&tid=68
its not carcinogenic but inhalation causes nerve damage and paralysis of the arms and legs
