CP-8400 Autosampler on Varian GCMS
Posted: Thu Aug 22, 2013 8:53 am
Hi all,
I'm using an old Varian 3800 GC with a Saturn 2000MS for pesticides analysis. We have quite a few of these within our laboratory but with I'm currently expericing a repeated issue with the CP-8400 autosampler (which isn't the best designed autosampler in the world!) on one of my instruments. This particular 8400 is repeatedly crunching the syringe needle several vials into the run and I'm at a loss as to what's causing it.
Some details of what I've tried so far:
All the best,
Aviator
- Each time I replace the syringe, I recalibrate the vial 0 and injector port positions. Alignment seems to be correct and it successfully injects several samples (between 8 and 10) before crunching.
- I replace the septum that sits within the injector port each run, so I doubt that it's the septum hardening with age!
- I've moved the samples onto another GC with an 8400 autosampler and that has injected without any problems so I don't think it's the vial cap septa.
All the best,
Aviator
