Sequential sequences on ChemStation
Posted: Tue Aug 13, 2013 10:56 pm
by biocat
Is it possible to submit multiple sequential sequences in ChemStation? It's a no brainer on EZStart but I don't see how to do it with ChemStation. Thanks!
Re: Sequential sequences on ChemStation
Posted: Wed Aug 14, 2013 12:17 pm
by shaun78
Granted, it has been a very long time since I used ChemStation ("A" days of the software). But, unless Agilent changed something, there is no way to queue sequences.
Posted: Wed Aug 14, 2013 3:36 pm
by KM-USA
The newer Chemstation has a Sequence Queue function.
On older versions just set up as one Sequence, with a specified wait time to equilibrate in between changes of Method.M.
Posted: Mon Aug 19, 2013 12:04 pm
by nimbi63
You didn't mention the revision of ChemStation you are using. This is a very important bit of info.
Many years ago (in the 'A' revision) a macro was added to the \UCL\LC_UCL\Macros for 'chaining sequences'. Check your ChemStation software disk for this folder, and look in the 'Index' to see if it exists on your revision.
Posted: Mon Aug 19, 2013 6:33 pm
by biocat
Thanks all for the info. The version is B.03.01-SR1 [317].
Posted: Tue Aug 20, 2013 7:13 pm
by nimbi63
OK, on that revision you would have to use the 'chain sequence' macro. It's on B.03.01 CD2 in \UCL\LC_UCL\Macros\10.
