Procedural question for the addition of TEA
Posted: Thu Aug 08, 2013 3:04 pm
Hi everyone-
So this why engineers don't need to be performing analytical chemistry work. If I read a procedure that call for a 35mM NaPO4 pH=7.5 w/ 1% TEA buffer w/ ACN gradient and I want to run salt on channel A and ACN on channel B, how do you make the salt solution?
In the past I've I've made an the pH=7.5 Na-PO4 up and then added the TEA at 1% and never thought about it. But I realized today that after adding TEA the pH shoots up to 11.xx. Am supposed to titrate after the TEA addition or am I doing it correctly by titrating the salt first then adding the TEA after............I think I've been doing this wrong because wouldn't you lose buffering capacity after adding TEA and pH shooting up?
