column for very high pressure chromatography
Posted: Mon Aug 01, 2005 5:37 pm
I currently work with a method HPLC which necessite to use a column RP C18 250*4.6mm with a flow of 2.5 ml/min and a great quantity of water (80%). Of course the pressure is high (around 4000 PSI). I don't have the choice, the method is imposed by USP. I would like to know if there are columns having its caracteristiques while having a lower pressure.
Thanks.
Thanks.
