Agilent HPLC diode array detector won't start!
Posted: Thu Jul 25, 2013 5:31 pm
Hello! I am having trouble with the diode array detector component of an Agilent 1200 series HPLC (with UV-vis detection). Simply put, it will not start up- no green light or anything. This has been an intermittent problem before this point- someone would attempt to start up the instrument, the diode array detector would refuse to light up, said person would make a coffee run and return to a magically up-and-running diode array detector. Unfortunately, it is no longer starting up, regardless of how many coffees we've purchased.
Switching out the light source and the power cables connected to the system did not alleviate the problem. Has anyone experience a similar problem and found a fix?
More about the system: The computer is an HP compaq running ChemStation ver B.02.01 on Windows XP. The software side had been glitching before this point, freezing up and not completing run sequences, then finally not even able to complete a single run. "Advanced system optimizer" software was run and found/fixed a multitude of problems (66,000 including one worm), but that has not seemed to fix our DAD issue. (Perhaps unrelated issues, but worth mentioning.)
Thanks in advance for any help or advice.
