Troubleshooting PPC Shutdown
Posted: Wed Jul 24, 2013 3:12 pm
Dear All,
I have a Perkin Elmer Clarus 500 GC in my lab. We have a capillary column connected to it. During the experiment, we got an error message saying CAR1 PPC shut down and the gas flow rate went down. We then replaced the carrier gas cylinder with a new one. Removed all the inlet connection lines and checked for leaks and reconnected it. Again after restarting the instrument, the pressure builds up and then slowly drops down and again PPC shut down occurs.
We tried to figure out if there are leaks at the column inlet and outlet as well and found no leaks.
We suspect whether the pressure sensor is having the fault.
Can anyone suggest any method to find out where is the exact problem and help in troubleshooting the issue.
Selva
Selva
