From what I can tell itis most often used with barbiturates, one uses a .1N solution in methanol and it is not water sensitive which is an added bonus as I can directly add my aqueous sample to it (my samples need warm water to break the starch encapsulation) So I can take like 20 ul of sample and 180ul of reagent and put it in a microinsert or it is also frequently reported to just draw 1ul of reagent and 1ul of sample and coinject them. Can a 7673ALS be setup to do this?
BTW It's often called flash methylation in the literature.
